gp.listfields Method
397
03-08-2011 09:54 AM
DuncanRager
Greetings,
Basic question... I'm trying to list out the names of all the fields in a particular shapefile.
Using the gp.listfields method in the following manner...
fields = gp.listfields("[shapefile_location]")
print fields
...I get a list of items resembling, "geoprocessing describe field object object at 0x032A2F0".
How can I print the actual field names?
DR
JasonScheirer
Occasional Contributor III
print [f.name for f in fields]
DuncanRager
Worked great, thanks.
So I'm getting a 'u' in front of each field name... what does that mean?
Also, is this method specific to anything, like the geoprocessing object maybe? In other words, if I had a simple list, say...
silverware = ["forks", "knives", "spoons"]
...and I input...
print [f.name for f in silverware]
...I would get an error. What's the difference between the lists?
DR
DanPatterson_Retired
the u stands for unicode (just ignore it)
>>> for utensil in silverware:
...  print utensil
forks
knives
spoons
as for the "name" thing, your simple example above has no name property whereas a field has a name property as well as several others (eg type, precision, scale if appropriate etc etc)
JasonScheirer
u means it is a Unicode object, as opposed to a regular (locale-specific) C-style string.
Doing this:
is trying to get the name property off the string, which does not exist, hence the error.
