Error 000046 Too many reference tables....
347
07-22-2019 09:23 AM
JoeBorgione
ArcGIS 10.6.1
I am trying to (re) create a python script that creates our locators as a scheduled task.  I'm running into a problem when creating a US Address - Single House; I get the above error.
I've tried several different approaches (os.path.join(), .format()) that toss the same error. I opened the help page and followed the example there where it sets the workspace env a priori and that errors out as well:
'''On line help snippet'''
arcpy.env.workspace = "C:/ArcTutor/Geocoding/atlanta.gdb"
Atlanta_AddressLocator_OutputPath = "C:/ArcTutor/Geocoding/Atlanta"
arcpy.CreateAddressLocator_geocoding("US Address - Dual Ranges", "streets 'Primary Table'",......‍‍‍‍‍‍‍‍‍‍‍
''' My snippet'''
locatorStyle = '"US Address - Single House"'
outLocator = '{}\ParcelAddress'.format(locatorsDIR)
parcelAddressSDE = r'I:\GIS\ArcSDE\SuperUser\is\slco@slcopub.sde'
arcpy.env.workspace = parcelAddressSDE
fieldMap = """
'Point Address ID' OBJECTID VISIBLE NONE;
'Street ID' <None> VISIBLE NONE;
'*House Number' HouseNum VISIBLE NONE;
blah,blah,blah....
arcpy.CreateAddressLocator_geocoding(locatorStyle, "ParcelsAggregate 'Primary Table'",fieldMap,outLocator,"","ENABLED")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Line 42:  ParcelsAggregate is a feature class within the given Egdb workspace....
Does using python and this style of address locator have some bad blood?
JoeBorgione
I changed a couple things in my python code, and now it works:
In line 3 of my snippet, I now use only single quotes:
'''was : "'US Address - Single House'"
#now:
outLocator = 'US Address - Single House'
Also, in line 16, I dropped the reference to 'Primary Table':
parcelAddressFC = r'{}\slcopub.SLCO.ParcelsAggregate'.format(parcelAddressSDE)
primaryTable = parcelAddressFC
arcpy.CreateAddressLocator_geocoding(locatorStyle,"{}".format(primaryTable),
                           fieldMap,outLocator,'',enableSuggestions)
Note line 7 where I don't add the extra text 'Primary Table'
