Optimised cartography maps in UNF
694
07-18-2019 06:41 PM
AnthonyRyanEQL
Occasional Contributor III
In the Benefits of the Electric Utility Network Foundation it talks about the included maps contain symbology optimised for use across the ArcGIS platform.
Can anybody please elaborate on this?
I'm trying to find out how the symbols were created and their associated parameters (eg. max size - 256 x 256px, 32bit colour, transparent background, no colour gradients, save as/export format - SVG, EMF, imported into stylx file as marker symbol, suitable applications to use - Inkscape, Adobe Illustrator, GIMP)
Thank you for anytime with this.
MikeMillerGIS
Esri Frequent Contributor
Anthony,
  The were built using SVG so they can be scaled larger or smaller without affecting quality.  They were also built with higher contrast to previous symbols so they are visible on top different basemaps available to ArcGIS users.
MikeMillerGIS
Anthony,
AnthonyRyanEQL
Michael,
I was assuming this was the case. Thank you for the confirmation.
Do you suggest a starting point when it comes to the pixel size? I know SVG scale so it probably just depends on the fine detail I'm trying to achieve in the symbol which may/may not be able to be seen at the finished size on the layer symbology.
MikeMillerGIS
For the editor maps, we used 18pt.  For mobile maps, we have made them larger in the past, around 22 would be good.
AnthonyRyanEQL
Thank you for this additional information
