Point Cloud Scene Layer not drawing
1150
6
07-19-2019 06:43 AM
JohnHuillery1
I've created a Point Cloud Scene Layer using the Create Point Cloud Scene Layer Package geoprocessing too and it will not draw in ArcGIS Pro.  The point cloud will flash for half a second then disappear.
The las file used to create the Point Cloud Scene Layer Package is a photogrammetric RGB point cloud created in Pix4D.
Andrew--Johnson
Can you answer some of these questions to help narrow down the issue?
What coordinate system is the slpk in?
Have you tried adding to both a global and local scene?
Have you tried turning off the elevation source to ensure it is not blocking the data?
Have you tried adjusting the display limit to say 9,000,000?
Thanks!
-Andrew
JohnHuillery1
CRS info (see below):
I've tried everything else that you had suggested, still not displaying anything.
John
Andrew--Johnson
Hi John,
Are you able to provide the las file so we can take a look on our end? If so, please provide your email and I can send you a FTP link.
thanks,
Andrew
JohnHuillery1
Any way I can private message you that?
Andrew--Johnson
To close the loop on this:
The issue is specific to the automatic view clipping mode. To get around this set it to Manual mode
1) Click on View Tab
2) In the View Clipping Group click the mode dropdown and select Manual
JordanJSimpson
Hi
I've also created a Point Cloud Scene Layer and it is not drawing, although I do not have the option to select  mode dropdown in the view clipping group.
I've tried the steps described above and they aren't helping either,
Do you have any suggestions?
Jordan
