Related View in Survey123 website is not working
656
07-18-2019 04:15 PM
AnuSawant
Occasional Contributor II
This should be an easy and quick one. I am accepting to view the related records only when I select any record from the primary table, but can't get the result. Not sure where going wrong? Is this only applicable for those Survey created by a new version?
Any suggestions would be helpful.
Anu
Jim-Moore
Hi Anu, thank you for the screenshots. Just to double-check, do you have the "Automatically select related records" option enabled?
There's also a filter to show only the selected records in the table (indicated by the arrow, above).
Jim
Jim-Moore
Hi Anu
The related table view should work with surveys published in older versions. Could you please provide some screenshots to illustrate what you're seeing?
Jim
AnuSawant
Hi Jim,
Thanks for the reply. I have attached a screenshot from Survey123 site. "A" is a primary table and "B" is a related table.
Anu
Jim-Moore
Jim
AnuSawant
Hi Jim,
Thanks for the help. It's working now. Sorry I just missed this setting
Thansk,
Anu
