Pro Tool not licensed
966
07-18-2019 12:10 PM
chadhickman
Occasional Contributor III
I keep running into a issue with my ArcGIS Pro software, every so often I try running an advanced licensed tool (i.e. a Spatial Analyst tool) I keep getting a message that the tool is not licensed yet I have an advanced license that is valid through 2020. I go to the licensing options and click advanced license but it still does not allow me to use the tool.
Any suggestion, tips, etc. would be GREATLY appreciated!!!
JoeBorgione
Spatial Analyst is covered under an extension license, not your ArcGIS Pro license.  You need to get a Spatial Analyst extension license assigned to you specifically in order to use any tools associated with it.
chadhickman
The Spatial Analyst tools have worked before. I have an advanced license
DanPatterson_Retired
So, project backstage, under licensing, Spatial analyst is licensed? and not expired?
Are you in one of those 'sharesies' environments, where all the available licenses may be checked out and hence not available... or are you working in a standalone environment with full control over your installation?
resolved?
