Using Repeats Survery123
501
07-17-2019 01:23 PM
by Anonymous User
Not applicable
I want to calculate the % cover of a vegetation transect, and have the % cover update as different points are analyzed.
a) is there a way to reference what repeat # I am on? (for example, say at point 1, there is veg cover; and the end of repeat 1 I want to show "100%" cover; and then at point2, if there is not veg cover, the calculation should say 50% cover, etc).
b) Can I do "count ifs" across repeats in survey123? I have a select-one question, and I want to be able to count across repeats the different answers.
Thank you!
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Kristen,
Survey123 supports the overall aggregation statistic capabilities through functions such as sum() and count(); the average is
sum(${q}) div count(${q})
One way to do a 'count-if' is to have a hidden question in the repeat that does the if statement returning the value you want if true and 0 if false.  You then can use a count() function with that hidden question.
