Set visibility of a layer when app opens to off
589
07-17-2019 05:09 AM
MarquesMunson1
Is there a way that I can set the initial visibility of a layer on the layerlist widget to off when the application loads? Then the user can choose to turn the layer on, if needed. I am in the configs LayerList json file. I believe that is where the adjustment is made but I am not exactly sure what to put. Any help is greatly appreciated! Thanks!
KenBuja
MVP Esteemed Contributor
You can turn off the visibility of the layer in the original web map.
KenBuja
MarquesMunson1
thanks so much! I thought there had to be some type of code to write.
