Reclaiming Portal licenses
1663
07-15-2019 04:45 PM
JasonRoper
New Contributor III
How do I get licenses back once generated?  I have created a .json file for a Portal that had 20 Creator and Viewer.  They were activated.  But we recently received 5 Editor and Field Worker licenses.  The file must now be recreated to included the 20 Creator/Viewer and the 5 Editor, Field Worker.  It doesn't appear that licenses can be de-authorized to returned to the pool.  How do we reclaim them to regenerate a new license?
JohnPlunkett
In MyEsri you need to cancel the appropriate portal license file
https://my.esri.com/#/provisioning/files/portal
Depending on where you are and what My Esri Privileges you have you may not be able to do this. If this is the case - contact your MyEsri Admin or your Esri Distributor or Esri Support
JohnPlunkett
