Zoom Transition between two views of the same map on Sidecar
2130
8
07-15-2019 11:37 AM
MatthewHowland
In the classic StoryMap cascade, one could add a map into an immersive section, then Duplicate that map to create another identical slide, but by adjusting the scale/zoom of the second map, the transition between the two would appear as a zoom in or out to the new map extent. The new StoryMaps app seems to lack functionality to duplicate a map within the Sidecar (which is fine since one can just add the same map again) but the possibility of a zoom transition, which is more aesthetically-pleasing than a simple fade transition, seems to be lost. Please let me know if I am overlooking something or if you have any advice.
Thank You,
Matt Howland
PS: in case it isn't clear what I'm referring to, the zoom effect I'm talking about is shown in this StoryMap, with the text beginning with "Web maps that occupy every last pixel because you don't want to waste pixels on not maps? Immersive!"   https://nation.maps.arcgis.com/apps/Cascade/index.html?appid=5cd671a4cf1844b7854220979574b927
OwenGeo
Esri Notable Contributor
Hi Matthew -- The ability to have transitions between sidecar slides that move the map or toggle layer visibility isn't available in the new ArcGIS StoryMaps just yet, but it is one of the features we are working on for release in the next few months.
Owen Evans
OwenGeo
Owen Evans
MatthewHowland
Thank you for your prompt reply Owen!
erica_poisson
Occasional Contributor III
Hi Owen,
Is there anywhere we can find dates of next releases of StoryMaps with projected improvements?
Erica
Erica
deleted-user-Q7YCQS4CXs1p
This was the best thing about StoryMaps - when will it be available again?
BenjaminMittler
Any updates on whether this is possible yet? I'm trying to get this functionality to work in a scene.
JulieGrindborg
New Contributor III
it has been 3,5 years since it would reappear in "the next few months", when will this be possible again? This was also one of my favorite things about storymaps.
OwenGeo
@JulieGrindborg -- This capability was added to ArcGIS StoryMaps back in late 2019, so it has been available for a long time. I'm sorry this thread wasn't updated.
However, please note there was a bug introduced a few weeks ago that is currently preventing this from working as expected. We plan to fix that bug this week, so this will be back to normal in a few days.
Owen Evans
OwenGeo
Related thread: Solved: Re: Story Maps have lost auto zoom function to con... - Esri Community
Owen Evans
