I would like to understand why sometimes arcpy.Exists() return True sometime False depending how I write the path of the featureClass.
I have two databases with both a copy of the same featureClass
In database1, the featureClass Archives.DBO.Data1 is in the dataset Archives.DBO.Dataset1
In database2 the featureClass PROD.SDE.Data1 is in the dataset PROD.SDE.Dataset1
With arcpy, if I only keep the short names of the dataset and featureClass in the path arcpy.Exists() return True for database1 but False for database2:
import arcpy, os
FC_DB1 = os.path.join(r"C:\\", "Connexion", "Database1.sde", "Dataset1", "Data1")
FC_DB2 = os.path.join(r"C:\\", "Connexion", "Database2.sde", "Dataset1", "Data1")
arcpy.Exists(FC_DB1)
#return True
arcpy.Exist(FC_DB2)
#return False
If I write the full dataset and featureClass with database2, arcpy.Exist() return True
import arcpy, os
FC_DB2 = os.path.join(r"C:\\", "Connexion", "Database2.sde", "PROD.SDE.Dataset1", "PROD.SDE.Data1")
arcpy.Exist(FC_DB2)
#return True
Why writing the short dataset and featureClass works for the database1 but not for the database2?
Solved! Go to Solution.
The GeoNet Resource Hub space is for questions and issues about GeoNet itself. I am sharing with Python and Geodatabase.
