I would like to know how I can update a value in a table.
Here is my first go from looking at all the examples.
RowCursor cursor = profilesByStation.Search(null, false);
string nameoftable = profilesByStation.GetName();
int riverField = cursor.FindField(General.MMCProperties.Instance.getPropertyAsString("FieldsProfileRiverCode"));
int reachField = cursor.FindField(General.MMCProperties.Instance.getPropertyAsString("FieldsProfileReachCode"));
int stationField = cursor.FindField(General.MMCProperties.Instance.getPropertyAsString("FieldsProfileStation"));
int measField = cursor.FindField(General.MMCProperties.Instance.getPropertyAsString("FieldsProfileRef"));
string refMileField = General.MMCProperties.Instance.getPropertyAsString("FieldsXsRefMile");
if (riverField == -1 || reachField == -1 || stationField == -1 || measField == -1) {
System.Windows.Forms.MessageBox.Show("An error was encountered when trying to update the refmile data. The river field, reach field, station field, or measField was not found.\r\n");
return;
while (cursor.MoveNext()) {
Row row = cursor.Current;
object river = row[riverField];
object reach = row[reachField];
object station = row[stationField];
if (!(river is System.DBNull || reach is System.DBNull || station is System.DBNull)) {
Models.XSecLocate xSecLocate = Models.XSecLocate.findXSecLocate(xSecLocateList,Convert.ToString(river),Convert.ToString(reach),Convert.ToDouble(station),true);
if (xSecLocate != null) {
row[measField] = xSecLocate.Meas;
row[refMileField] = xSecLocate.Meas;
As you can see I am updating the row/column field value by
However when I do this, it doesn't appear that anything in my table was updated.
Hi James,
I would check out the ProConcepts Editing help topic. This snippet can probably be modified to solve your issue.
I hope this helps,
--Rich
