Grid Theme and RepeatsI
1440
07-11-2019 06:02 AM
Chris_Anderson
Occasional Contributor II
If this has been addressed in previous post, I apologize.
Is there an issue with applying the grid theme to a repeat? I have a survey that uses a grid theme, but fails when I try to apply it to a repeat; it collapses on itself and only shows a small part of the question with the garbage can, repeat count, and + at the bottom (see image below). Everything works great til I change the width of a question, then the collapse happens. Is this a known bug/limitation of the grid theme?
Hope the UC is going well. Will be there next year.
Chris Anderson
Florida Fish and Wildlife Commission
DougBrowning
MVP Esteemed Contributor
You need to add a group inside the repeat right away.  And give it a size.
Note you cannot grow a repeat down though.  It will still show one at a time with a + button.
DougBrowning
Chris_Anderson
Thanks a bunch. That worked.
Chris
