ArcGIS Pro project holds the python environment to be used
1121
7
07-09-2019 03:22 PM
AnthonyRyanEQL
Occasional Contributor III
Hi all,
Is there a setting or something within the ArcGIS Pro project that sets which python environment is uses? At the moment, I have 2 users environments (one for the Utility Network Foundation and the other for running scripts in VS code) as they have very different requirements and don't want to have package dependences version issues with the main tools that I'm using.
I'm currently using ArcGIS Pro 2.4 with ArcGIS Enterprise 10.7.1
DanPatterson_Retired
Anthony can we assume you have multiple environments that you can activate?
Python Package Manager—ArcPy Get Started | ArcGIS Desktop
AnthonyRyanEQL
Dan,
I definitely do. I have the master (arcgispro-py3) and 2 users envs (un & dev)
so you did...
After changing the active environment, you may need to restart ArcGIS Pro to reinitialize Python and use the new environment.
And if that didn't work, then you need to explore where the packages were in installed
       1                                       2
C:\arc_pro\bin\Python\envs\arcgispro-py3\Lib\site-packages
"1" is the install folder for arcgis pro.
"2" is the environments in the 'envs' folder... you should have the base arcgispro-py3 and 2 others.
I don't bother cloning since I have full admin rights to my machine, but if you want to separate environments that is ok/good.
/blogs/dan_patterson/2018/12/28/clone
But your packages need to be present in the correct environment.  I always use 'conda' to install/manage my packages
/blogs/dan_patterson/2018/07/01/arcgis-pro-your-conda-environments
AnthonyRyanEQL
Dan,
Thanks for this but it's still not what I'm after.
I'm trying to find out if I have 2, 10, whatever number of cloned environments available to use and I have ArcPro open to use one of those environments (eg. one of the environments is setup for Utility Network Foundation), is there a setting in the ArcGIS Pro project that knows to use that environment when it opens every time instead of having to switch & restart if its changed?
JoeBorgione
That's an interesting question.  I just tried it between the default env and my clone.  As you indicate, which ever you use last is what the next project opens up with.  Could be an ideas submission waiting in the wings....
Kory Kramer
Ok... now I see what you want.
No.  You have to switch manually and generally/sometimes restart Pro
AnthonyRyanEQL
Thanks all for looking at this. I'll submit an idea
