Required fields in SmartEditor
405
07-07-2019 10:54 PM
AmandaSandström2
New Contributor III
When will the required function in SmartEditor work in Portal? As I've understood this functionality is only available in ArcGIS Online at the moment.
RobertScheitlin__GISP
Amanda,
   The big thing to understand is that portal is several versions behind AGOL WAB.
https://enterprise.arcgis.com/en/portal/latest/use/about-versions.htm
I would say upgrade to 10.7.1 Portal and you will be good.
