Route result time and distance with units
1128
8
07-05-2019 09:39 AM
ADITYAKUMAR1
Occasional Contributor III
Hi ,
   I am using routeresult to get the result of my route. I am getting the length for each segment as well as time.
array.forEach(routeResult.directions.features, function (feature) {
var direction = feature.attributes;
directions.push(direction);
The output is
1: {length: 0.01642324482308207, time: 0.15858421215735188, text: "Go northwest", ETA: -2209161600000, arriveTimeUTC: -2209161600000, …}
Can I get something like
The unit as been set as esriMiles in my code.
Any suggestion will be really helpful.
Kumar
RobertScheitlin__GISP
Kumar,
   Why are you setting the direction length units to esriMiles when you are wanting the output to be in Meters?...
ADITYAKUMAR1
Hi Robert,
 The image is just for reference.I am getting miles for distance but I am not sure of time unit as I have not set any time unit there.
 Kumar
Kumar,
   In your output you have time and ETA...
ADITYAKUMAR1
Yes.
What I want to know is the units of length: 0.01642324482308207(which I suppose is Miles) and unit for time: 0.15858421215735188?
I am not able to get the unit of time. Is it minute/sec/hr?
Kumar
Time is in milliseconds
ADITYAKUMAR1
Thanks a lot Robert. It resolved the issue. But is there any way where we can get the unit of time? Because at the total time its giving me 22.05 which i suppose is minutes
number.format(routeResult.directions.totalTime);
Kumar
As I mentioned the unit will be milliseconds. So you just need to format/convert the milliseconds to what ever unit of time you want.
ADITYAKUMAR1
Yes.
Kumar
