Near tools returns null
1256
10
07-02-2019 09:37 AM
SammiFan
Hello. I used Near tool in ArcMap 10.3 to calculate the nearest distance between the county center and US time zone boundaries. But I got all the fields with a null value. The county center is calculated by following the instruction here: https://support.esri.com/en/technical-article/000009381. And I also add a time zone layer by searching online. However, when I use the Near tool to calculate the nearest distance from each county center to time zone boundaries, each field returns null.
I couldn't figure out a way to fix that. Any hints are appreciated. Thank you so much!
DanPatterson_Retired
Near—Help | ArcGIS Desktop
NEAR_FC
The catalog path to the feature class that contains the near feature. This field is only added to the output table if multiple Near Features are specified. If no near feature is found, the value will be empty string or null.
Are all the layers in the same coordinate system?
And it appears you specified multiple Near Features?
An online layer is probably not in the same coordinate system as your data are.
SammiFan
Thank you so much for your reply!
I am not sure about the system. But if I download the time zone layer to my computer and use this downloaded one, will they in the same coordinate system?
And I only want the distance from the county center to the nearest time zone boundary. Is that a problem?
Sammi, nothing automatically gets put into the same coordinate system.  Find out what the coordinate systems are, and if needed use the Project Tool (in Data management, projections and transformations toolset) to project the downloaded one into the coordinate system of your main data
SammiFan
Got you! I will do some research about the coordinate system and then redo the process. Will keep you posted. Thank you so much!
Good luck Sammi and welcome to GeoNet
SammiFan
Hi Dan, I find out that their coordinate systems are:
GCS_WGS_1984
GCS_WGS_1984
It seems like they are in the same coordinate system. Still not sure what the problem is....
SammiFan
And now when I try to generate near the table, just several has numbers, and all others are 0.
0 is the distance... the closest is inside
SammiFan
That's possible. Then I guess I would like to ask is it possible to calculate the shortest distance between the point and the nearest time zone and the point is not located in the time zone?
Thank you!
