Custom widget in webmap
475
07-02-2019 12:46 AM
IBGemeente_Amsterdam
Hey Esri community,
I'm working on an interactive map and I found this custom widget called EDraw which I want to use for this. I have been able to get in in the webappbuilder and make a template out of it, but the problem is that its hosted on my local pc. So if I shut down the program I cant access it anymore. I'm not very good with networking, but is it possible to host this on Arcgis Online just like a webmap that I would make on there? This way I will be able to share it within my organisation.
Kind regards,
Bram van den Berg
RobertScheitlin__GISP
Bram,
   If you are saying that you are wanting to use a custom widget in an AGOL app then you can not do that. Custom widgets are supported in WAB Developer and on Premise Portal but not on AGOL.
