Just updated to 2.4 and now when exporting a layout to an image file, the "transparent background" option is selected by default; is there a way to change this so the background is not transparent by default?
Hi!
With the new Export Pane in Pro 2.5 your settings are remembered after you export a layout. So if you export one layout without a transparent background, next time you go to export (in that project, or a different project) that option will be checked off.
