Reproject a point with arcpy?
3082
03-05-2011 02:58 PM
DennisGeasan
Occasional Contributor II
I would like to use arcPy to reproject XY point fields in a table to a different coordinate system.  Essentially do the same as the Calculate Geometry option but from a Python script.  Is it possible?  I can't find any functions in arcPy that provides reprojection of the point values derived from the 'shape' field or from XY values stored as attributes.
DG
KimOllivier
Occasional Contributor III
There is a projection parameter option on the cursor objects that will reproject to new coordinates as you read the records. Getting a transform to work as well is a bit tricky, but basically set that as well as a string.
# extent_xy.py
# add extents of parcels in NZMG to a NZTM dataset for backward compatibility
# update to use on the fly projection directly from NZTM layers
# see Werner Flacke's book and script example
# updated for 9.2
# Kim Ollivier 13 April 2007
# input NZTM coverage library, parcel and plabel coverages
# output csv files to load and join back to coverages using AML
# issues solved:
#               add spatial reference to SearchCursor
#               define a Geographic Transformation that works with a coverage
#               because coverages cannot define NZGD2000 use WGS84 definition
#               or the transform is ignored
import os,sys,glob,arcgisscripting
gp = arcgisscripting.create()
def parcel(tile) :
    print "Parcel",tile
    ws = "e:/lib/nztm/tile/t"+str(tile)+"/data"
    outfolder = "e:/lib/nztm/tile/t"+str(tile)+"/data"
    ds = ws + "/parcel"
    f1 = open(outfolder+"/e_parcel.txt","w")
    f1.write("par_id,eminx_nzmg,eminy_nzmg,emaxx_nzmg,emaxy_nzmg\n")
    gp.Workspace = ds
    print ds
    # this is a good on-the-fly switch for the searchcursor
    # srOut must be a com object, not a file ref or a factory code
    rows = gp.SearchCursor(ds+"/polygon",'"PAR_ID" > 0',srOut)
    n = 0
    rows.Reset()
    row = rows.Next()
    while row  :
        print >> f1,"%d,%s" % (row.par_id,row.shape.Extent.replace(" ",","))
        row = rows.Next()
        n +=1
    del rows
    print n,"Polygons"
    f1.close()
    return
def plabel(tile) :
    print "Plabel",tile
    ds = ws + "/plabel"
    f2 = open(outfolder+"/e_plabel.txt","w")
    f2.write("par_id,eminx_nzmg,eminy_nzmg\n")
    gp.Workspace = ds
    rows = gp.SearchCursor(ds+"/point",'"PAR_ID" > 0',srOut)
    n = 0
    rows.Reset()
    row = rows.Next()
    while row  :
        n += 1
        print >>f2,"%d,%s,%s" % (row.par_id,row.shape.Extent.split()[0],row.shape.Extent.split()[1])
        row = rows.Next()
    del rows
    print n,"plabels"
    f2.close()
    return
# ------ main ----
srOut = gp.CreateObject("SpatialReference")
srOut.CreateFromFile("c:/arcgis/nzmg.prj")
# WGS_1984 works for coverages defined with an equivalent custom Transverse projection definition
gp.GeographicTransformations = 'NZGD_1949_To_WGS_1984_3_NTv2' # ;New_Zealand_1949_To_NZGD_2000_3_NTv2'
# but is this being used?
inFC = "e:/lib/nztm/tile/t1009/data/plabel/point"
# not at 9.3?? outFC = "in_memory/dummy1.shp"
outFC = "c:/tmp/dummy1.shp"
outPrj = "c:/arcgis/nzmg.prj" # cannot be a COM object or factory id 43040
geoTrans = "NZGD_1949_To_WGS_1984_3_NTv2" # ;New_Zealand_1949_To_NZGD_2000_3_NTv2"
if gp.Exists("c:/tmp/dummy1.shp") :
    gp.Delete("c:/tmp/dummy1.shp")
gp.OverwriteOutput = 1
gp.MakeFeatureLayer_management(inFC,"tlayer","PLABEL# < 3")
gp.Project_management("tlayer",outFC,outPrj,geoTrans)
try :
    if sys.argv[1].upper() == 'ALL' :
        lstTile = range(1001,1013)
    else :
        lstTile = [ tile for t in sys.argv[1].split(",")]
except :
print "begin extent_xy"
for t in lstTile :
    print t
    parcel(t)
    plabel(t)
