How can I add old Survey responses to new survey?
355
06-27-2019 11:41 AM
by Anonymous User
Not applicable
I may have made a lot of extra work for myself.....
recently I had the great idea to delete some old files from my AGOL account (for no real reason) while I was doing this I must have deleted a service definition that was needed to keep my Survey working. After deleting these items I went to survey123.com and was going to generate some reports, only to find my Survey was GONE! This is an issue as the data and responses are a large part of the work done by my coworkers. I do have the hosted feature layer with the point data and responses in the attribute data so i am not completely out of luck. I still have the survey excel file on my Survey123 connect on my desktop. I am wondering if it is possible to republish the exact same survey and add the old responses to the new survey? Most likely from the hosted feature layer. Has anyone experienced this issue before? Is it possible? Do I have to manually add all 87 surveys to the new one?
Any help would be greatly appreciated.
KassandraRodriguez
Republish the new survey and the new feature layer will have the option to append data like pictured below.
KassandraRodriguez
by Anonymous User
Not applicable
Kassandra,
Thank you for the quick response. I did just as you instructed and everything worked perfectly! I have messed up some of the statistics, namely the submission stats. Now it looks like I submitted all 87 surveys, but the most important things have been remedy.
