I have a project that has parcels, roads, etc. in it (I use this project a lot) and a SID image,…a 2017 NAIP image. When I want to edit a layer, and I click on the little editing pencil, it automatically checks the SID image to be edited (a major no-no). When I un-check the SID image, I get this error:
The exception Breakpoint
A breakpoint has been reached.
(0x80000003) occurred in the application at location
0x00007ffe5671725E.
Click OK to terminate the program.
Anyone else having this issue?
Solved! Go to Solution.
Hi Pete Magee
Thanks for posting this. I'm sorry that you experienced a crash in ArcGIS Pro. I'm able to easily reproduce this issue and have reported it to the development team.
If you leave that box checked are you able to continue your work without issue? Because as the icon shows in the List by Editing view, raster layers aren't editable, so it shouldn't matter if that is checked or not.
Please be sure to send error reports if they occur so that the development team can assess these and deliver fixes. Here is a bit more background on how the process works: https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/arcgis-desktop-error-reporter-lea...
Thanks again.
Hi Pete Magee
Thanks again.
I will try that and report back.
Pete Magee
I did edit successfully without unclicking the sid image and everything was fine. Thanks again Kory for your help!
Pete Magee
You're welcome. We'll have the team take a look at this crash to get it fixed...
I got the same error today when I had unchecked a tile package while in the List by Editing view. I re-opened it and didn't unclick the tile package and was able to successfully edit the shapefile I needed to edit.
Sorry you ran into this, Marjorie but glad you were able to move forward. I'm pretty sure that the fix for this will be in the ArcGIS Pro 2.4 Patch 1 coming later this week so keep an eye out for that.
Cheers
The patch fixed it! Woohoo!!! Kudos to the development team.
Did you reinstall the Transmorgifier Library?
