Hi
I have 3 layers : Road Center-line , Street Name Sign (SNS) and Addressing Number (ANS) as shown in figure :
I want put range numbers of every road id in the SNS Panels . For example in road id 2187 ranges should be from 1 to 45
Ok sounds good. But did you have a question?
If you wanting to give the roads address ranges. Typically E911 format is to have four Attributes.
FromLeft, FromRight, ToLeft, ToRight.
You need to know the increasing direction and what side is odd and what is even.
If your range is 1 to 45 and odds are on the left with an increase from East to West you would start the FromLeft with a 1 and the ToLeft as 45
FromRight would be 2 and ToRight would be 46. You would want to go 46 in this example to keep the same number of Address numbers in both right and left
