Power BI and Map Issues
1070
06-26-2019 09:45 AM
MicheleGoltz
Hello, I'm am using Power BI and have loaded it on the cloud.  When I try to look at the maps using Internet Explore 11 the maps freeze up.  However, when I use any other browser like Chrome or Edge I don't have this issue. Also I don't have esri plus just using the basic so I thought it should work.  Is there still an issue with esri maps and Power BI using Internet Explore version 11.
Second issue is I'm try to export to a PDF from online and it goes through the motion but when the file opens up where the map should be it say. "This visual does not support exporting".
Can you not export to PDF?
