This seems like it should be pretty simple, but I've been troubleshooting and can't seem to get it to work!
//I create an Edit operation
var splitFeatures = new EditOperation() { };
//Some Extra code goes here (https://github.com/TxDOT/Pro-LRS-Tools/blob/master/LRSTools/IdentifyRouteLocations.cs for full code) that splits and gets measures
splitFeatures.Split(lyr, oid, geometry);
splitFeatures.Execute();
//I Undo the Split
splitFeatures.UndoAsync();
//After I undo the edit operation, I want to remove the ability for the user to redo it. How can I remove the single edit operation from the redostack?
var operationMgr = MapView.Active.Map.OperationManager;
//operationMgr.FindRedoOperations()
//RemoveRedoOperation();
I found this RemoveRedoOperation method, but I can't seem to find a good example of it in use. Please help!
JP
Narelle Chedzey , I attended some of your Dev summit sessions about editing. Do you have any insight into this issue? Thanks!
