ArcMap Report
422
06-21-2019 06:47 AM
ChrisSlattery
Hello
I am trying to create a report in ArcMap. Each point in the file has attachments (photos). I am trying to get the photos onto the report. I have added the RelatedReport from the design elements to the report template in the report designer but the photos still do not appear. Does anyone have any ideas?
Chris
David
by Esri Contributor
I haven't done this before, but I found some help in another post. It seemed to work.
This is possible. Just be sure of the following:
- Add a RelatedReport element to your primary report layout (in the detail level in my case).
-Double click on the RelatedReport to open it in design view.
Add a Picture element to the RelatedReport
Change the image source of the Picture element (right hand side in element properties) to the "DATA" field
Change the Size Mode to Stretch (works best for me)
Arrange the size of the Picture element so it takes up most or all of the space of the RelatedReport
Arrange the size of the RelatedReport itself in design view of your primary report to ensure you have the image sized and aligned properly.
Run the report and you should be good to go!
Found here: Insert / Export attachment photos to report ?
ChrisSlattery
Thanks. I did find this also. This is ok for 1 photo. Multiple photos for each point. it will put all of them in one column.
