ArcGIS Rest API – Webhooks - Microsoft flow Survey123
1178
6
06-17-2019 06:18 AM
PaulSweeney3
Occasional Contributor III
I am trying to follow the instructions in the link below to automatically update a layer after submitting a survey in Survey123
https://resources.esri.ca/getting-technical/webhooks-microsoft-flow-and-the-arcgis-rest-api-automati...
However i am failing at the final hurdle and receiving this error message
The execution of template action 'While_Loop' failed: the result of the evaluation of 'foreach' expression '@{body('Parse_Query_JSON')?['objectIds']}
' is of type 'String'. The result must be a valid array.
 Can anyone give me some idea as to what i am doing wrong?
COSPNWGuy
Hi Paul Sweeney,
I expect it is because when Flow autogenerated the schema when you uploaded a sample json, it takes a guess at the type of data (many times erroneously). All you need to do in your schema is delete the type or change it to integer.
PaulSweeney3
Hi thanks for you response (I really should have posted an update here) i had eventually figured this out and this was exactly what i did i removed the types and it worked perfectly. This is a really useful tool for us now.
ILoveMap
New Contributor III
Hi Paul,
I'm having a similar problem with this same workflow. Would you mind showing me your HTTP query operation and following Parse JSON connector?
I'm a bit lost and getting the same error, so any help is appreciated....
PaulSweeney3
Hi Chris
See below. you only need a header as per my screen shot then a post
then for each object id in th e query you need to apply the edit as per below
FYI i have migrated to integromat as i find it more user friendly.
ILoveMap
New Contributor III
Hi Paul,
Thanks for the reply. With your help I was able to get my query to work but it looks like I'm running into the same issue as your original post described. When the last component (POST - Update Features) attempts to run. Any insights you may have on this would be appreciated.
{"error":{"code":400,"message":"Cannot perform operation. Invalid operation parameters.","details":["'features' parameter is invalid","Invalid JSON primitive: ."]}}
PaulSweeney3
Hi Chris
you need to look at the json in your Body , you have a comma after your colon Object ID:, you need to remove it.
