Network Dataset and Enterprise geodatabase
505
06-13-2019 08:02 AM
AlfonsoDodero
New Contributor III
Hello everyone,
I have a road feature class within a feature dataset of an Enterprise geodatabase.
I need to create a Network Dataset on this geodatabase that includes the road feature class for making analysis in my local machine. I encountered the following problems:
1) Being able to create the Network Dataset only via ArcGIS Desktop, the feature class is not recognized  in the "creation Network Dataset wizard"  when it has Attribute rules (made with ArcGIS Pro). This problem is solved by removing them. Is it normal or do I have to update ArcGIS Desktop? (from 10.6 to 10.7)
2) Once the Network Dataset has been created, I cannot edit features because the registration as versioned is missing. Furthermore I can't set the Network Dataset existing in the .sde as a source for the Network Analyst.
I currently have a license for the Network Analyst extension only for ArcGIS Desktop and not for ArcGIS Enterprise, can this be the problem?
Thank you!
