Populating answers from barcode
457
06-13-2019 11:29 AM
DavidKrady
Is it possible to populate fields within a survey with choices that are associated to barcode numbers? For example, If I have pipes that need to be serviced, can I have information on each specific pipe type (size, status, location, etc) within the excel sheet that will be related to the barcode number so when scanned, the information will populate?
Thanks.
CPoynter
Occasional Contributor III
Have a look at these 1 / 2. Should have the information required. Look into pulldata() function.
