rolandd
Navigate a Map Frame In ArcGIS Pro 2.3.3
Discussion created by rolandd on Jun 13, 2019
Within the layout tab, I am not able to zoom into an activated map frame in ArcGIS Pro 2.3.3.  I need to delete the map frame and re-add it for the zoom functionality to be restored.  I am using "Map Series Pages" as well.  Also, the "Layout Properties" under "Map Series" don't give me the option to maintain the current map extent.  If I select the option for "Center and Maintain Scale" the map extent changes slightly and I am not able to use the "Undo" tool to revert back to my previous map extent.
If it helps, Data Driven Pages in ArcMap allowed me to set a specific map extent.
Outcomes
