How to change all fields aliases to lower case in ArcGIS PRO
641
06-13-2019 12:57 AM
KydyrovMeirambek1
Please help to generate python script or something else to bulk change aliases to lower case
JakeSkinner
Esri Esteemed Contributor
Hi Kydyrov,
You can run the following script in ArcGIS Pro:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
fc = "Parks"
for field in arcpy.ListFields(fc):
    print("Updating field: {0}".format(field.name))
    try:
        arcpy.AlterField_management(fc, field.name, "", str(field.aliasName).lower())
    except:
        print("\tUnable to update {0}".format(field.name))
        pass
