Hi ArcGIS Pro SDK professionals,
I am trying to create a stand-alone CoreHost application. It's quite easy task if you are an experienced ArcObjects SDK developer.
I have a problem when I try to save edits to the Oracle SDE geodatabase. Feature.Store() method "inside" Geodatabase.ApplyEdits() throws an exception:
ArcGIS.Core.Data.GeodatabaseObjectClassException: Objects in this object class cannot be updated outside of an edit session. ---> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x80041354
at ArcGIS.Core.Internal.IRowIOP.Row_Store(IntPtr rowHandle)
at ArcGIS.Core.Data.GeodatabaseUtil.Store(IntPtr rowHandle)
--- End of inner exception stack trace ---
I have tried to save edits without ApplyEdits. Same result.
The feature class is a non-versioned SDE feature class (database table). It has lots of relationship classes (sub database tables).
If I edit data (using the same source code) of another feature class (without relationship classes), no exceptions are thrown. That's why I wonder if the CoreHost implementation does not support editing non-versioned feature class having relationship classes.
Do you have any idea what I am doing wrong? Or is there really above-mentioned restriction?
Jorma
Hi Jorma,
Would you be willing to share a code sample? There should not be any restrictions like you have described, although it's always possible that there is a bug in this area.
--Rich
