Export of filegeodatabase fails
527
06-10-2019 05:21 AM
JonasOstberg
Hi when i attempt to export file database the export fails. Excel export works. I have quite large data selection. Red box says that "export failed".
WhitneyWeber
Like you, I was unable to export my survey to gdb via survey123.arcgis.com but was able to successfully download the survey to gdb via the Python script referenced in this document. I don't know why this happens nor how to avoid it but would be very interested to know as well! The Python script may offer a workaround for you too.
JamesTedrick
Esri Esteemed Contributor
Hi Jonas,
Can you try exporting to file geodatabase via the ArcGIS Online Item Details page for the feature service?
JonasOstberg
Hi James
That did work, Thank you.
