AnsweredAssumed Answered
ArcGIS Pro: Label Settings Window Closes Before I'm Finished
Question asked by deleted-user-M1PJmvnAl3Pp on Jun 6, 2019
Latest reply on Jun 28, 2019 by wharrison-esristaff
A coworker and I have experienced a possible bug regarding labeling settings in ArcGIS Pro. We are both on version 2.3.2 and run Windows 10 and 7 respectively.
It manifests itself as follows:
1. Right click on a layer in the Contents pane and click on Labeling Properties....
2. Go to the Position tab (note: there is no Apply button at the bottom of this window). Change any setting.
3. As soon as a single setting is changed, the change is applied, the Labeling Properties window closes, and is replaced with a window that says "Select a feature layer in the Contents pane".
This is really annoying because I cannot change multiple position settings at a time. I have to go to contents and get the Labeling Properties window open again, make a change, watch it close, and do it all over again to make a third change, and so on.
Is anybody else experiencing this?
Outcomes
