Failed to connect to database.
1970
06-06-2019 12:00 PM
SLouq
by MVP Regular Contributor
Whenever I try to expand an .xlsx file in ArcCatalog to bring into ArcMap to do a join, ArcMap gives the error
'Failed to connect to database. An underlying error occurred. Class not registered.'
So I searched the ESRI forums for a solution to this and found I need to install a 2007 Microsoft driver but
when I click on the link to take me to the download page it says.
Sorry Page does not exist anymore.
Can someone point me to the correct webpage where I can download this driver?
Scott
by Anonymous User
Not applicable
This is likely the article they are referencing: https://support.esri.com/en/Technical-Article/000013670
You can install the 2016 version (attached to the article above) or other versions.
by Anonymous User
Not applicable
