Raster calculator "if, then, else" statement
10758
06-02-2019 11:33 PM
KK2
New Contributor III
Does anyone know if in Raster Calculator it is possible to build more complex condition than with the Con tool?
I would like to create a new column in my attribute table and evaluate the values in this column based on few different columns, e.g:
if value in column A > 50 give me A, then
if value in column B > 50 give me B, then
if value in column C > 50 give me C, then
if value in column D > 50 give me D, else
give me E
Any idea how to do this as one statement in Raster Calculator? Thanks in advance for your answers.
by Anonymous User
Not applicable
If you're working with a raster with an attribute table (and it sounds like you are), a better tool might be the Field Calculator, which can incorporate python scripts to process if/else statements. Here's some of the documentation on this:
Fundamentals of Field Calculations - http://desktop.arcgis.com/en/arcmap/latest/manage-data/tables/fundamentals-of-field-calculations.htm...
Calculate Field - http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/calculate-field.htm
I don't think there's a way to do this with the Con tool, but maybe others here will have other ideas!
Best,
Lauren
KevinMayall
Occasional Contributor III
curtvprice
MVP Esteemed Contributor
Reclassify won't work for this as it reclassifies the data in a single value field.
I agree with Lauren that working with Calculate Field in the raster table may be (much) more efficient, but I'm wondering how you got such a "fat" raster table. If the fat table was output from the Combine tool, you may want to skip the Combine tool and do this instead using the five input rasters:
Con("RasterA" > 50, "RasterA",
    Con("RasterB" > 50, "RasterB",
    Con("RasterC" > 50, "RasterC",
    Con("RasterD" > 50, "RasterD",
    "RasterE"))))
