Survey123 hidden question multiple-choice
376
06-03-2019 09:47 AM
LanaRadloff
I'm trying to use the relevant column to display a hidden question with the relevant multiple choice answer. I've used the expression: selected(${VegetationCover},'Other'). But, when I select 'Other' from the multiple choice list, the text box to specify what other is doesn't appear.
Would somebody be able to help me figure out what I've done wrong?
Thanks!
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Lana,
Just to check, is the name value of the choice 'Other' or something different (likely 'other')?  The selected() function uses the name, not the label, in its comparison.
