UN MODEL for Electrical
587
06-01-2019 04:53 AM
SrinivasaRao1
New Contributor III
HI UN Team,
We are looking for UN Model Sample for electrical and please do share if you have one as a sample data for reference in understanding the migrate to UN Model from ESRI network model.
Srinivas
AnthonyRyanEQL
Occasional Contributor III
Srinivas,
When you read through the Getting Started documentation (http://solutions.arcgis.com/electric/help/electric-utility-network-configuration/get-started/get-sta...), there is a step where they talk about setting up the Solutions Deployment addin which allows you to download the sample dataset and ArcGIS Pro package
SrinivasaRao1
New Contributor III
Hi
I have got the data but I could not able to proceed further due to the errors seen.
MikeMillerGIS
Esri Frequent Contributor
Are you loading the sample data?  We have seen issue with parallel processing.  You can set it to 1 in the environment variables of the tool or run this in the python window prior to running apply asset package.
arcpy.env.parallelProcessingFactor = 1
