Is it possible to cross filter when there is more than 1 layer in the map?
398
05-31-2019 01:44 PM
NoelPerkins3
New Contributor III
I have noticed that when I add additional layers to a map card I am no longer able to cross filter. I would like to be able to show the data I am filtering and see the geographic area it falls in. Is there a work around?
LindaBeale
You can add as many cross-filters as you like.  Remember they must be added to each card that you wish to be cross-filtered.  Additionally, remember to see interactivity data must come from the same data set (or join them) otherwise they do not know what is in common.  Joins can be done using the create relationships or even by enabling location if that is the data you have in common.
LindaBeale
