What is a good Best Practice Map or Data Guidelines ?
699
05-31-2019 07:48 AM
PROBERT68
or should I say to find a good best practice a guideline that I'm looking for a checklist sheet to  reduce errors on map or data  ?  They can be from ESRI, or anywhere where I can read about them.
DanPatterson_Retired
Everything will be an option
Dr Google using
"mapping best practices"
ie
http://proceedings.esri.com/library/userconf/fed16/papers/fed_86.pdf
although for some reason it is not loading
but chuck 'esri' onto the end
Best practices for using layers in maps—ArcGIS Online Help | ArcGIS
https://www.esri.com/content/dam/esrisites/en-us/media/pdf/architecting-the-arcgis-platform.pdf
and loads more.
Switch up to
'digitizing best practices'
'databases best practices'
You get the drift.... hopefully something will jive with your workflow
Dr Google using
ie
and loads more.
Switch up to
PROBERT68
Thanks, I was able to open the proceedings from ESRI and it takes some time to open it and it works.
