ArcGIS Pro 2.3.3 patch install errors 1304 + 2349
1897
6
05-26-2019 10:11 AM
JonHall
Occasional Contributor II
After installing ArcGISPro_23_167023.exe, NOT for all users, just myself, installation folder defaulted to my user directory, instead of C:\Program Files\ArcGIS\
Then, installing ArcGIS_Pro_233_168940.msp failed at every attempt, whether as a "software update" in ArcGIS Pro, or running the downloaded MSP.
First, 1304 error, followed by 2349 error.
Neither error appears in the UpdateLog.txt (attached)
Prompted to make sure I "had access to" the folder, I did indeed have access, that was not the problem.
Following tips in https://community.esri.com/discussion/create.jspa?containerType=14&containerID=2151 I turned off virus scanning and firewall, that was not the problem, either.
Uninstalled Pro.
Reinstalled Pro "for all users", in default C:\Program Files\ArcGIS\
Patch installed without errors.
DanPatterson_Retired
Did you right-click on the msi and run as Administrator? (with Pro closed obviously)
JonHall
Yes
Strange then, the only difference I can see is when I installed Pro and upgrades, I didn't use Users, but I install directly in:
C:\arc_pro
Other fluff goes into Users
C:\Users\... name ...\AppData\Local\ESRI
C:\Users\... name ...\AppData\Local\ESRI\conda
KoryKramer
Esri Community Moderator
Strange behavior.  The documented install location for a per-user install is here:
https://pro.arcgis.com/en/pro-app/get-started/arcgis-pro-installation-administration.htm (that's the location whether you install silently or not.  Pro 2.4 doc will be updated to make these locations more clear).
If you need the software installed only for you, not all users on the machine, and are running into errors, please reach out to Technical Support: https://support.esri.com/en/contact-tech-support
RobertJones3
Thanks for posting this. This worked for me with version 2.8 patches that were erroring out.
myeager
I know this topic is old, however this may help someone in the future.
If you run ArcGIS Pro as administrator prior to installing patch, this should resolve your issue.
