Passing parameters to a Survey123 where the field is in a group
858
05-24-2019 05:53 AM
SimonPhillips
I am looking to pass parameters from Workforce, and the project's web map, I've hit an issue when trying to set a field which is contained within a group.
If I have the following schema in my form
typenamelabel
textsitenameSite Name
textnameFull Name
If I launch the survey and pass in the default values for these fields using the following url
https://survey123.arcgis.com/share/{GUID HERE}?field:sitename=SITE123&field:name=MYNAME
The Survey get populated with both the values I passed in.
If I then modify the survey definition and add a grouping
typenamelabel
begin groupperson
textnameFull Name
end group
Using the the same url only the sitename field is now populated. I wasn't expecting name field to populate, however I should be able to access it by modifying it's path e.g. person/name or person.name etc. I have tried all sorts of separators e.g. _, __, . and %2F and am not really getting anywhere.
Can anyone shed any light on how to access nested fields, or point me to the documentation?
Si
References
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Simon,
I am able to get a sample based on your description working.  See:
https://survey123.arcgis.com/share/6ab38cb6c2fa4e5caaacd12fa7cba807?field:sitename=Test123&field:nam...
Can you try to set up the URL with the test survey?  Also, can you check to see that spaces (and other special characters) are being properly percent-encoded?  A space may stop the reading of the URL.
