ArcPro: untools will nor load
469
05-23-2019 01:11 PM
LarryAdgate
I am running Pro Version 2.3.1 and I am trying to set up a Utility Network:
 I have Installed the ArcGIS Solutions Deployment Tool, Cloned Environments and deployed the Utility Network. Everything seemed to work except the untools will not load. I searched and found it but the install tab will not highlight. See attached
Thank you for your help.
Larry Adgate
Golden State Water Company
AnthonyRyanEQL
Occasional Contributor III
Larry,
In your attached screenshot, there is a warning message about you can't modify the default python environment.
You will have to create a new environment by cloning the default and then download the untools python library
AnthonyRyanEQL
Larry,
LarryAdgate
Thank You,
Larry Adgate
