Drone2Map not producing any output when I run it?
615
05-22-2019 10:26 AM
KennyLegleiter
I started using Drone2Map last year and it worked.  I am using version 1.3.2.232.  I haven't used it in several months until yesterday.  Starting yesterday, when I try to process drone imagery, I don't get any results in the output folders that Drone2Map creates.  The folders are empty.  I am using the default settings, the same imagery that I used last year when it did work, but now nothing.  The processes report says project complete, but nothing created.
According to the log report, I am getting these error messages:
2019-05-22 10:50:21,331 ERROR - Error getting elevation from ElevationQuery Response: Token Required
2019-05-22 10:53:09,772 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 10:56:43,921 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 11:14:09,434 ERROR - Error moving tile folders: The process cannot access the file '7ac877a6-85c3-4e3e-801d-d9b9c81a596e.tif{FS-DRONE_SL_peerlock.srv}.pslock' because it is being used by another process. 2019-05-22 11:23:25,412 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 11:23:25,465 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 11:23:25,472 ERROR - Error creating DTM: Object reference not set to an instance of an object. 2019-05-22 11:37:26,904 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 11:37:26,946 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 11:37:26,960 ERROR - Error creating DTM: Object reference not set to an instance of an object. 2019-05-22 11:44:48,822 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 11:44:48,865 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 11:44:48,880 ERROR - Error creating DTM: Object reference not set to an instance of an object. 2019-05-22 11:47:26,518 ERROR - Error getting elevation from ElevationQuery Response: Token Required 2019-05-22 11:53:35,157 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 11:53:35,188 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 11:53:35,194 ERROR - Error creating DTM: Object reference not set to an instance of an object. 2019-05-22 12:05:42,435 INFO  - Loading User Camera DB 2019-05-22 12:05:42,439 INFO  - Reading User Camera DB XML 2019-05-22 12:05:42,441 INFO  - Deserialized User Camera DB XML 2019-05-22 12:06:17,307 INFO  - Successful Heartbeat on 5/22/2019 12:06:17 PM 2019-05-22 12:07:05,563 INFO  -  Processing Started - killing process tree for pid: 11828 2019-05-22 12:08:55,527 INFO  - wkhtmltopdf response:  2019-05-22 12:08:55,535 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 12:08:55,562 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 12:08:55,567 ERROR - Error creating DTM: Object reference not set to an instance of an object. 2019-05-22 12:12:09,124 INFO  - wkhtmltopdf response:  2019-05-22 12:12:09,132 ERROR - Error creating Orthomosaic: Object reference not set to an instance of an object. 2019-05-22 12:12:09,165 ERROR - Error creating DSM Hillshade: Object reference not set to an instance of an object. 2019-05-22 12:12:09,174 ERROR - Error creating DTM: Object reference not set to an instance of an object.
Any suggestions on getting Drone2Map working again?
Thank you.
BrianCarson2
Hey Kenny,
In order for us to best troubleshoot the issue, I would suggest having a case created with Technical Support. That will allow us to take a look at your configuration, and possibly obtain the data for testing in-house to see if we are able to reproduce the behavior on our end.
Best,
Brian
