How to average climate data in a Raster- Dataset?
2343
7
05-22-2019 03:04 AM
LeonhardH_
I am utterly new to ArcGIS Pro.
I downloaded monthly precipitation data, in the GRIB- format, from 1979 - present.
It was possible for me to create a Raster- Dataset and it shows me now the different values with a color gradient and a time dimension.
But what I need to do is averaging the data that ist shown every month over the 40 years,
so I can see the mean monthly precipitation in one view that contains the last 40 years.
I would be glad if someone is able to help me.
Leonhard
KoryKramer
Esri Community Moderator
Are you able to use the Cell Statistics function to calculate the mean of the multiple time layers? https://pro.arcgis.com/en/pro-app/help/data/imagery/cell-statistics-function.htm
LeonhardH_
Yes I already did it, but are you sure that it calculates the mean over the time dimension?
What would you think of the Space-Time-Cube, but I didnt suceed with it?
DanPatterson_Retired
Are the data daily values? for 40 years? and you want monthly values by year?
Are your data an array stack? or single rasters?
LeonhardH_
It is already averaged monthly data and I want the average for 40 years.
The data is in one GRIB- file so I would say single rasters.
cell statistics will give you the average.  It is location based, so each cell will receive the chosen statistic for the time period you specify.  In this case, it will yield a 40 year average of your monthly averages.  If you want to isolate particular months prior to averaging, then this will have to be done as a separate operation prior to cell statistics.
LeonhardH_
I guess there is just one Raster (TP@SFC).
And in the blue map you see the data for the first month (I can use the time slider). When I carry it out, the blue map doesn`t really change.
LeonhardH_
I think that this is the problem:
If a single raster is used as the input for maximum, minimum, mean, median, majority, minority, or sum, the output pixel values will be the same as the input pixel values.
