Question on Editing Data on Survey123 Website
355
05-15-2019 06:45 AM
AntonioGarcia
I am a little stumped.  I am trying to edit data through the survey123 website, but when I try to click the "edit" tool, it doesn't allow me to access the tool to edit (SEE BELOW - when hovering over the tool it states, "Editing existing records is not currently supported for surveys published with Survey123 Connect").  Does this mean I cannot edit data through this window at all or is this a feature that can be turned on or off?
Any help would be appreciated.
KassandraRodriguez
That features are only editable if you made the survey through web not connect.
MikailaBell
New Contributor III
I edit data in a map table. Arc Pro is best, but AGOL works too.
