Im using #ArcGIS Pro.
I have four rasters. All rasters are the same in size/Footprint/Boundary but from different time of the year.
I have loaded rasters into#Mosaic dataset.
Im looking for a processing template for mosaic dataset that would let me to choose which raster of the year to display.
I believe I should have 4 separate raster processing templates.
The reason Im looking for a template is that I will need to use it on published mosaic data set later.
Any advice would be greatly appreciated.
Regards,
Ben
Benas,
cant you just add a Date Field to the Dataset, add the image date into it and then allow 'By attribute mosaicking' using the time field and enable time as a property in the Mosaic so that as a service this time settings can be used to display by time?
If you explicitely want to go the other way, look at this documentation page
https://pro.arcgis.com/en/pro-app/help/data/imagery/using-mosaic-dataset-items-in-raster-function-templates.htm
there the section about
"Set up the raster function template to use groups of items from a mosaic dataset"
and create a template that uses the ItemGroup logic (though you will only use one image at a time) - in your case actually the only thing you would need is to specify a query in the template ...
Regards
Guenter
Guenter Doerffel | Technology Evangelist Imagery & Raster Analytics, Europe
Esri | Weena 695 | P.O. Box 29099 | 3001 GB | Rotterdam | The Netherlands
M +31 (6) 83 83 56 15 | GDoerffel@esri.com | esri.com
THE SCIENCE OF WHERE™
