Error viewing data on Survey123 web
408
05-15-2019 11:38 PM
Li_ShuenNg1
Hi, I've been working with repeats to add multiple geopoints in survey123 connect. I have 4 of these repeats for each section of my surveys, each section has a geopoint function and several questions which act as attributes for the geopoints. The survey layout seems to be right, but I had to test the survey to see if the data is properly recorded. When I checked the data, I got an error message: "An error occurred while loading the page. Some features may not work". What could be the problem? Could it be that my schema is not supported?
Here is a snippet of my xls form for 2 sections of the survey:
Any ideas?
JamesTedrick
Esri Esteemed Contributor
Can you share your entire XLS file?  And to confirm, you are viewing  in the web form, correct?
