Aligning Problem
1880
5
05-14-2019 08:00 AM
BurakAydin1
New Contributor III
Hello there,
I have a problem. As soon as I click "Align shapes to Terrain", my shapefile rectifies and falls down the edge.
In the first picture(Border_Issue1) you can see that all shapefiles have the right size, in the second picture(Border_Issue) you can see the mentioned problem.
Does anyone have the same problem and can help me? Thomas FuchsChris WilkinsElliot HartleyDavid WassermanGeoff TaylorL RCheryl LauMatthias BuehlerMichelle Mathias
Thanks in advance
by Anonymous User
Not applicable
Hi Burak,
Try one of the Translate options. Project will cause the effect you see if any of a shape's vertices extend past the edge of the terrain.
Chris
BurakAydin1
New Contributor III
Hi Chris,
thank you for your quick answer. However, the problem persists.
In the beginning everything worked fine, see the picture below(it's my backup-file). But after I created a .3ws file for the Cityengine Web Viewer, the problem occurs strangely.
Burak
ThomasFuchs
Hello Burak Aydin
Can you pleas provide a screenshot of the CityEngine Web Viewer scene?
Is it really the shape files that are wrong?
Or does the terrain itself look strange?
Thanks for your help!
Thomas F
BurakAydin1
New Contributor III
Hi Thomas,
in the appendix you can find the screenshots. You can see the Cityengine scene and the terrain (DGM1&2) as a whole and close up.
I don't know if it can be because of the terrain. The strange thing is that everything worked fine in the beginning, but now this aligning problem arises when i want to add new shapefiles.
Burak
BurakAydin1
New Contributor III
Hi there,
I found my mistake. The shapefiles were polygons and after I converted them into multipatches everything works fine again.
I don't know if this is the general solution now, but in my case it works fine.
Thanks for your replies and help
Burak
