How to open widget inside a popup
954
7
05-13-2019 11:33 PM
webappbuilder5
hi robert,
I have doubt,when we click widget button is it possible to open the widget in popup instead of panel,please let me know anything about this.
thanks
Tarun
VictorTey
Not possible as far as i know if it is a build in widget. However if it is a custom widget you have written, there is nothing stopping you from setting inpanel to false in the manifest file. Then implement your own html panel.
webappbuilder5
Thanks for support victor,you solution will not satisfy my requirement.
My requirement is to open custom widget in popup,instead of panel,please let me know any thing regarding this.
RobertScheitlin__GISP
As Victor already mentioned. It is not possible with a standard in panel widget.
webappbuilder5
Thank you for your response,
Is there any possibility of opening custom widget in popup window ,please suggest.
Sorry I have never attempted that so I do not know.
LeoLiu1
Hi Tarun,
You probably can configure a feature action for your custom widget?
https://developers.arcgis.com/web-appbuilder/guide/create-a-feature-action-in-your-widget.htm
VictorTey
Are you referring to windows popup? if windows popup then you can always call windows.open in your widget.js. However interaction between a child window and parent window can be a real pain.
May I ask whats the reason you would want a widget in a html window and not a dojo panel?
